As the whole thing says, "How Do I Topset?"
Is there a way to do it on the new desks or could this be a feature in later software releases? It is such a pain when one lamp blows and leaves 1 or 2 on the same circuit still on, whole thing looks uneven.
Here's hoping .................. :unsure:
Si
backSTAGE Theatre Supplies LTD
Specialists in
Lighting / Staging / Consultancy
Setup - Edit Fixtures - Topset
Press the SETUP key. Select the [Edit Fixtures] option, select the fixture(s) to be edited, Select the [Topset] tab. Use the cursor keys or mouse to select the required fixture, press ENTER, enter the required topset value, press ENTER. Repeat for each required fixture. Select [OK] in Edit Fixtures window. Press SETUP to exit setup.
(Leap Frog 48/96 Operating Manual - Issue 2 - Pages 43-44)
