matmax Posted January 10, 2008 Report Posted January 10, 2008 Hi, I will buy a Jester ML24. But, there is not lamp. Can I put an USB lamp ? And can I put an USB hub ? So, I can put 2 lamp and my USB stick. Sorry for my english, I'm french. Matmax Quote
Paul Posted January 10, 2008 Report Posted January 10, 2008 Yes you can use a USB Lamp with the desk - the desk can supply 0.5A on the USB Port. Unfortunately memory sticks or keyboards will not work on the other side of the hub. Quote
trumpetsteve Posted March 25, 2008 Report Posted March 25, 2008 Just wondering. Ive been using the Jester for a couple of months now and love using it. One of the things that does get quite irritating is constantly changing over USB accessories. Unplugging my USB LED light to save a show on a USB stick, then plugging in a USB keyboard for doing something else. Today i found it handy having the jester around as i could charge my ipod on it (however it crashed when i plugged it into the ML, worked fine with the 24/48 though!) Would i be able to plug a USB hub - or would zero88 have to come up with patchbay on the back or something for more USB ports? thanks Steve Quote
Kenneth Watt Posted September 20, 2009 Report Posted September 20, 2009 Unfortunately memory sticks or keyboards will not work on the other side of the hub. Sorry - What do you mean by that? I'm using the Jester 24/48, not ML. Would it still work in the USB port? Thanks Quote
Paul Posted September 21, 2009 Report Posted September 21, 2009 Unfortunately USB hubs will not work with any of the Jester, JesterML or JesterTL desks. Quote
Kenneth Watt Posted September 21, 2009 Report Posted September 21, 2009 Ok thanks Would a USB light still work on the standard Jester 24/48 tho? Thanks K Quote
Paul Posted September 22, 2009 Report Posted September 22, 2009 Yes you can use a USB Lamp with any of the Jester desks - the desks can supply 0.5A on the USB Port. Quote
