Brian Eades Posted January 1, 2008 Report Posted January 1, 2008 Is it possible to edit memory blind (say Q.23) when another memory is has been played back(say Q.25)live.If so as I have tried this the blind screen does not inform you what memory you are about to edit blind. Look forward to any replies thanks. Brian Quote
K-Nine Posted January 2, 2008 Report Posted January 2, 2008 Yes, it is possible ... First put the Program Window into Blind Mode ... Press the BLIND key on Special Page 1 of the MFKs. Then load the memory to be edited into the programmer ... Select the memory to be edited on the Memories Window, then press the LOAD key. Adjust the dimmer levels and/or fixture parameter values as required, then press the UPDATE key to update the memory. For further details on Blind Mode and editing memories see the Leap Frog 48/96 Operating Manual pages 91 and 103. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
