Brian Eades Posted January 1, 2008 Report Share Posted January 1, 2008 Is it possible to inhibit a generic fixture if it is not doing what you want it to do,ie colour burns out or gets knocked out of focus.It could then be ihibited from the other memories until end of show when you can then put the lamp right. Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted January 2, 2008 Report Share Posted January 2, 2008 You could do this using the Topset function, which is found in Edit Fixtures. Press Edit Fixtures, then select the fixtures required. Move to the "Topset" tab, and select the topset required for the fixture. Note that this is a topset rather than an inhibit, so it will limit the maximum value of the output, rather than scaling the output down. We have talked about adding Inhibitive submasters to a future software version. Quote Peter Kirkup Link to comment Share on other sites More sharing options...
K-Nine Posted January 3, 2008 Report Share Posted January 3, 2008 There is also the possibility of a 'Park' function which could also be considered for a future version of software if that function would be useful. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
