OFFSET
Pipo
The 'Offset' parameter is a specific movement effect parameter, one of the six parameters that define a movement effect.
The wheel editing modes which include the three fan-functions are used to fan out the values of any fixture parameter across the selected fixtures.
The fan-functions can be used on any of the four attributes (brightness, colour, beamshape or position).
Can't you add the offset parameter to color or beamshape just like you can make a movement-wave you would be able to make a color-wave using the fan-and offsetfunction?
Or is offset ONLY for pan and tilt?(what i simply do not understand)
Den Pipo
Pro Light Design
Dear Pipo,
K has mentioned before that offset is only working on "movement effects"
what you want to reach is a colour wave on some washlights - just a example Hold the colour parameter button you will see that you can use the fan function to increase colour value - it works very fine - I´ve tried it before with 6 washlights. If you want to automatically switch or fade thru the colours or beamshape have a look at the frog function - could be very useful too.
Sebastian H.
Pro - Sound Showtechnik
Albert Einstein
Al Capone
Hi Pipo,
as Haytech told, you may use the "Fanfunction" to create i.e. a rainbow run with washlights. First choose a yellow for all selected washers. Then switch into the "FanFirst mode" and add i.e. cyan. This could be the first step of a chase. Repeat these steps but change the "FanFirst" to "FanLast".
Well, I think the Fan function is what you meant by "offset". In the Position section the OFFSET relates to the selected effect and speed and is just a part of the whole effect engine.
Like Keith has in his notes....*:-)
I hope this is of help.............
Cheers Sven :mrgreen:
Sven Paulsen
Klangfarbe Vienna
