playboy Posted October 29, 2003 Report Posted October 29, 2003 I hope i become a little help. I have an old 6 Channel analog Betapack. I have problems with the channel 3 4. I'm looking for a Service Manual. It is an old Machine from 1992. Thanks for you help. Sorry for my English I am German. Thanks for replies . :oops: Quote
Haytech Posted October 30, 2003 Report Posted October 30, 2003 Hallo duck, nun was hast Du für Probleme mit deinem Betapack ? Treten Sie nur bei Channel 3 & 4 auf ? Hast Du die elektrischen Verbindungen geprüft ( CEE Stecker ) oder in einer Festinstallation die Sicherungen der Phase L2 ? MFG Haytech Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
Mars Posted October 30, 2003 Report Posted October 30, 2003 Zero88 excels in technical support on this issues, contact Keith Rogers. Find your local servicepoint at: http://www.zero88.com/en/distributors By the way, I will send you my copy anyway. ////////////////////////// Three things that determine the purchase: features, pricing and... service. ////////////////////////// Quote
Franck Posted October 30, 2003 Report Posted October 30, 2003 Hallo duck, was für ein netter Name für ein technisches Forum Na dann machen wir mal einen deutschen Eintrag. Kontakte mich bitte, um die Probleme mit Deinem Betapack zu klären. ftiesing@zero88.com Cheers Franck Quote
playboy Posted November 20, 2003 Author Report Posted November 20, 2003 Danke an alle die mir mit Tips bzw.Schaltplan helfen konnten! Es war der Vorwiderstand der Z-Diode bei der Auswertung der Phase.War von 100K so hochohmig geworden,das keine Auswertung mehr möglich war. Vielen Dank an das gesamte Forum!Tolles Team hier Quote
Franck Posted November 21, 2003 Report Posted November 21, 2003 Hey duck, ... you are very welcome 8) Cheers Franck Quote
techbppac Posted October 30, 2007 Report Posted October 30, 2007 Hello, I have an old Betapack. On certain channels when a lantern is plugged into it, theres no control over the dimming the lantern just stays on. On another channel the lantern will dim accordingly but only to about 50%, it will then just cut off-no fade. Please help, many thanks Quote
graviton Posted November 20, 2007 Report Posted November 20, 2007 hello I've got a probleme with an old betapack 1 Channels 3 and 4 are at full everytime have you a idee for me excuse my english!!! I'm french!! thanks graviton! Quote
