Carl Ehrhardt Posted December 14, 2007 Report Share Posted December 14, 2007 i have found a Strange behaviour on updating an Memory. Situation: LeapFrog 48, Software Version: 2.15 I have programmed a Cue 1 (Channel 36@100) Fade times to the next Cue No. 2 is 3 Seconds. Now i have to update Cue 1 and add Channel 1-6 @ 50. So i go to the PGM Window. Push update (Cue only). Now i start with Cue 1 by pressing go. cool - 1-6 are @ 50. Go to Mem 2 (black out) 36 fades in 3 seconds but 1-6 don't fade. they go off in 0 Seconds. I have switched on Cue Only and Smart Tag. As soon as I change the Fade times in Cue 1/2 +1 sec -1sec it works correctly. is there something I make completely wrong or is this not working right? Greetings - Carl Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
K-Nine Posted December 14, 2007 Report Share Posted December 14, 2007 This sounds like a bug to me. Any dimmer/brightness channels that are programmed with non-zero values in memory 1 should fade to zero when memory 2 is triggered in the fade down time defined in memory 2. Reference: LF-1882 Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Carl Ehrhardt Posted December 14, 2007 Author Report Share Posted December 14, 2007 Thanks and have a nice day. Carl Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
Brian Eades Posted December 29, 2007 Report Share Posted December 29, 2007 This sounds like a bug to me. Any dimmer/brightness channels that are programmed with non-zero values in memory 1 should fade to zero when memory 2 is triggered in the fade down time defined in memory 2. Reference: LF-1882 this has happened to myself during our pantomine I updated a cue to add 4 parcans ,the next cue was a black out these same 4 pars stayed in the black out.In the end I had to overwrite the cue. Quote Link to comment Share on other sites More sharing options...
Carl Ehrhardt Posted April 15, 2008 Author Report Share Posted April 15, 2008 This sounds like a bug to me. Any dimmer/brightness channels that are programmed with non-zero values in memory 1 should fade to zero when memory 2 is triggered in the fade down time defined in memory 2. Reference: LF-1882 Well same problem on the new Version 3.0 on the Frog :-( if you load the show again it sems to work korrekt but normaly we only safe the show for backup. Well it also would by a nice feature :-) if we can chose a different fadetime for a few dimmers this would also be nice - but not the way it's working right now. Thanks for fixing it soon! Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
