kgallen Posted December 10, 2007 Report Posted December 10, 2007 Hi, On a FatFrog in Full (NOT Partial) mode I am having some problems with programmed chases with generics (no movers) when played back from a normal programmed cue stack with the Go button. Using 10.8, if I do a run-time override of a chase modifier (e.g. Attack) for the currently output sequence, then sequences subsequently played (with Go) have the wrong chase modifier - wrong in that it isn't the programmed setting. This is when doing a simple run-time override rather than an F3-based select and pickup (no need, only one chase running). I have back-tracked the desk OS to 10.4 and cannot reproduce this behaviour; I can change run-time chase modifiers at will and the next chase will revert to the programmed setting as expected. I have played with this a number of times - swapping the desk OS between 10.4 and 10.8. It seems that 10.4 always behaves and with 10.8 you can induce the behaviour described above. Quote
Paul Posted December 11, 2007 Report Posted December 11, 2007 The way chase modifier overrides work on the stack was changed significantly in version 10.8, since with tracking, it's theoretically possible to have hundreds of chases all outputting from different tracked memories. As a result of this the bug you highlighted crept in, in that the chase modifiers are not reverted to programmed values once the memories stop outputting. The problem actually exists in both Partial Mode and Full Mode. Frog Reference 5591 - Chase modifier overrides on memories don't get reverted to programmed values once the chase stops outputting. Quote
kgallen Posted December 18, 2007 Author Report Posted December 18, 2007 This bug appears to be fixed in 10.9. Thanks guys Quote
Transalp Posted January 3, 2008 Report Posted January 3, 2008 Hello all! At a New Year's Eve party I had an other problem with the programming of a chaser: It should be a simple four-step-chaser for generic PAR-lights at a memory. But my colleague and me had no chance to create it correctly. Every time it lost its content of the first two steps. The steps were only dark, but the other two steps looked like programmed. We tried on and on, on different ways, switch the desk off and on, nothing worked. After downgrading from OS 10.8 to 10.4 the problem was fixed and the chaser worked correctly. Does someone know this problem allready? Dietmar Quote
