Hallo,
I hope in the new release the function the MFG button Drive & Speed & go on.
I think the function must:
select submaster or memory in the window
press the MFG button and change value and save in the select submaster or memory.
or how must the function.
Bye, Thomas
If you are referring to the chase modifier keys on Special Page 1 (Direction, Brightness Attack, Drive, Speed etc.) then these are designed for temporary live adjustment of chases as they are running.
If you wish to edit a chase and save the updated modifiers then this should be done via the Memory Setup Window or the Submaster Setup Window, as appropriate.
