Hallo,
i have found 2-way to programm a submaster/memory:
1. way
- press [sUBMASTER] (or Memory)
- press Submaster [FLASH] (or change memorynumber)
- values in a programmer
- press [RECORD]
and now open a Windows (submaster/memory is record with other values) with the question: overwrite or turn to Chase or cancel.
for the next step for the same submaster/memory only press record.
2. way
(not open the submaster or memory windows)
- press [RECORD]
and now open a Windows (submaster/memory is record with other values) only the question: overwrite YES or NO.
and now i have one wrong button press and my chaser lost.
I think the Question by the 2. way must always the question for 1. way.
I this function now a BUG or a feature. ;)
Bye, Thomas
The fact that you can program a memory or submaster with the Memory/Submaster pre-selected in the corresponding window or if a different window is active by pressing the RECORD key and then selecting a memory or submaster to program is by design :P
However, the fact that in the first case you get options to overwrite or turn into a chase but in the second case you only get an overwrite option is a bug. This has been logged (LF-1876, LF-1877) and will be fixed in the next version of the software.
