pierotec Posted November 26, 2007 Report Share Posted November 26, 2007 Hello, how can mix filters Cyan, Magenta and yellow of a fixture, on three UDF at gradual mode. We have probably change the parameters of the fixture with the fixture editor, but as I do. Thanks Quote Link to comment Share on other sites More sharing options...
K-Nine Posted November 26, 2007 Report Share Posted November 26, 2007 You need to assign a fixture parameter to a UDF: Select the fixture(s) that you wish to control via the UDFs. Select the attribute and wheel group such that the parameter(s) is displayed on the touch screen above the control wheels Enter the following command: SHIFT [parameter] RECORD <UDF> [parameter] indicates touching the required parameter (eg Cyan) on the touch screen <UDF> is flash button associated with the UDF you wish to record the parameter on. So for example to set up three UDFs to control the CMY parameters of a fixture Select the fixture. Press the COLOUR key and check that the Cyan, Magenta and Yellow parameters are shown on the touch screen. Enter the following commands: SHIFT [Cyan] RECORD <UDF 1> SHIFT [Magenta] RECORD <UDF 2> SHIFT [Yellow] RECORD <UDF 3> Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
pierotec Posted November 26, 2007 Author Report Share Posted November 26, 2007 Ok, done. Thank you Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted November 27, 2007 Report Share Posted November 27, 2007 You may also want to set up the UDF to be LTP-MIX mode, which will grab the parameter level and then enable control, as opposed to the default (LTP mode) where control is grabbed as soon as the fader is moved. Quote Peter Kirkup Link to comment Share on other sites More sharing options...
pierotec Posted November 27, 2007 Author Report Share Posted November 27, 2007 Ok, sure, albeit with different parameters the problem of mix does not arise. Thanks Quote Link to comment Share on other sites More sharing options...
