Mix Cmy
pierotec
You need to assign a fixture parameter to a UDF:
Select the fixture(s) that you wish to control via the UDFs.
Select the attribute and wheel group such that the parameter(s) is displayed on the touch screen above the control wheels
Enter the following command: SHIFT [parameter] RECORD <UDF>
[parameter] indicates touching the required parameter (eg Cyan) on the touch screen
<UDF> is flash button associated with the UDF you wish to record the parameter on.
So for example to set up three UDFs to control the CMY parameters of a fixture
Select the fixture.
Press the COLOUR key and check that the Cyan, Magenta and Yellow parameters are shown on the touch screen.
Enter the following commands:
SHIFT [Cyan] RECORD <UDF 1>
SHIFT [Magenta] RECORD <UDF 2>
SHIFT [Yellow] RECORD <UDF 3>
