Carl Ehrhardt Posted November 26, 2007 Report Posted November 26, 2007 I am not shure - maybe i am wrong... I add a new Fixture like Mac250. I chose a MFK and fader 48. So I can control the intensitiy direct with the fader and i don't have to use the intensitywheel on position. If i'm duing so - the Mac250 doesent work right. I only can control the intensity but not the position, color,... if im just using a MFK it's working fine. Is this a bug or is it a user mistake ;-) Thanks for help. Greatings from Switzerland - Carl Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch
K-Nine Posted November 26, 2007 Report Posted November 26, 2007 On Special Page 1 of the MFKs, use the [Flash Mode] key to set the flash mode to off/select. The flash buttons below the preset faders can then be used to select/deselect the fixture(s) you have assigned to the fader(s). When a fixture is selected, the LED in the flash button is lit. Once the fixture(s) have been selected, use the COLOUR, BEAMSHAPE or POSITION keys to select the required attribute. The corresponding parameters for the selected fixture(s) should then be adjustable via the control wheels. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Carl Ehrhardt Posted November 28, 2007 Author Report Posted November 28, 2007 Great - it works! So this post is not a bug - it's a "how do I..." thank you. Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch
