Hi Everyone I'm new to this so be gentle.
When I record cues some cues have a blank time instead of default time, as a result cue playes back as a snap,unless you use the override knob.You cannot even edit the times.
Brian Eades
Times appear as blank if there are no channels recorded for that attribute in that cue. For example, if no colour attributes change in a cue, the colour fade time will be blank.
There is a known bug in version 2.0 where unprogrammed channels will snap if you jump around the cue stack out of sequence - this has been fixed in our current beta test software and will be fixed in the next release.
Leap Frog 48/96 Operating Manual (Issue 2) - Pages 101 - 102
Setting Fade and Delay Times
Identifies the various fade and delay times associated with a memory and desribes the various methods of editing them :P
