Martins-Sublevel Posted November 23, 2007 Report Share Posted November 23, 2007 Hello! 1) Does this console has built in shapes? 2) How many steps are in one chase? 3) Can somebody explain me about functionality of Submasters and about possibilities of them in this console? P.S. I'm sorry if I write something stupid, becaus only thing what i have used before is Martin Freekie Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted November 24, 2007 Report Share Posted November 24, 2007 1) Does this console has built in shapes? Yep, there are currently 4 shapes - Ellipse, Fig 8, Triangle & Square 2) How many steps are in one chase? Upto 999. Each step you record uses up one memory, so the more steps you have, the fewer total memories you can record. The total number of memories depends on which fixtures you're using and how many of them. 3) Can somebody explain me about functionality of Submasters and about possibilities of them in this console? Submasters are ideal for mixing several lighting scenes together using faders. Imagine having a set of wash lights and a set of spot lights. You can bring up one submaster to point the wash lights at the stage, and one submaster to point the spot lights onto the podium. By separating the segments, you can reuse the podium fader whilst pointing your wash lights at another area. The JesterML24 takes this a stage further as you can assign a single channel to a submaster, if you want. Only moving light channels that are 'tagged' will be recorded - hold down TAG/UNTAG and move a wheel to untag a parameter, or hold down TAG/UNTAG and press COLOUR/BEAMSHAPE/POSITION to tag/untag all parameters under that attribute. Hope this clears things up. Quote Peter Kirkup Link to comment Share on other sites More sharing options...
