I was just wondering what people reccomend for houselight control with a fat frog?
I'm intendeing to use the second DMX universe, and assigning to a submaster on an almost perminant basis.
Does this sound sensible and if so how do you do this?
Thank you
Hi
The second output on a Fat Frog outputs the same data as the first output (they are paired)
Therefore, to patch and use the second output, all you need to do is find a free channel (or a fixture) and patch it to the relevant DMX address, then record the submaster in the same way as normal.
I hope this helps
Peter Kirkup
