rasskin Posted November 2, 2007 Report Posted November 2, 2007 I was just wondering what people reccomend for houselight control with a fat frog? I'm intendeing to use the second DMX universe, and assigning to a submaster on an almost perminant basis. Does this sound sensible and if so how do you do this? Thank you Quote
Kirkup_xp Posted November 7, 2007 Report Posted November 7, 2007 Hi The second output on a Fat Frog outputs the same data as the first output (they are paired) Therefore, to patch and use the second output, all you need to do is find a free channel (or a fixture) and patch it to the relevant DMX address, then record the submaster in the same way as normal. I hope this helps Quote Peter Kirkup
