Morn Posted November 2, 2007 Report Posted November 2, 2007 I assigned two Hungaroflash USDMX strobes as fixtures on my v10.8 Fat Frog. I made a scene with Brightness at 100% and my desired flashrate and saved it on submaster. The problem is, when I flash this scene, strobing doesn't stop anymore unless I stop it manually via fixture wheels. (USDMX strobe flashes at lowest intensity, even when brightness channel is on zero, as long as the Rate Channel is up.) Is there a way, that when I release the flash button, the LTP value goes back to zero again? BTW: Assigning the strobes on the faders isn't an option, because I have to control 84 PAR-Cans, 4 8Lights and 2 Theater Spots with them and there is no single fader left anymore. Quote So, if you don't start drinking...I'm gonna leave!!!
K-Nine Posted November 2, 2007 Report Posted November 2, 2007 On the Frog series of desks, the LTP channels programmed in the submaster data (colour, beamshape, position parameters) are only triggered when the submaster fader passes through the LTP trigger level for that submaster when the fader is raised. The LTP channels are not 'untriggered' or released when the submaster fader is brought down. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Morn Posted November 2, 2007 Author Report Posted November 2, 2007 I already feared that there'll be no chance to get the desired effect with submasters... This knocks my lightshow at sunday on the head. Quote So, if you don't start drinking...I'm gonna leave!!!
K-Nine Posted November 5, 2007 Report Posted November 5, 2007 If you have a spare submaster - you could simply program that to stop the strobe flashing. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Kirkup_xp Posted November 5, 2007 Report Posted November 5, 2007 Or use palettes to access the strobing? You can lock the palettes onto the flash keys by holding F1 and pressing Beamshape. Quote Peter Kirkup
Morn Posted November 6, 2007 Author Report Posted November 6, 2007 That was exactly my plan for continuous strobing at different rates. But I often have to use my strobes manually. Imagine for example a Heavy Metal or Metalcore song with some short double bass accents or fill-ins. I like to place a short strobe flash on every bass kick (e.g. kick 1 and 3 left strobe, kick 2 and 4 right strobe) I don't see how to manage this with pallets. The "stop fader" of course is an idea but isn't fast enough for those apocalyptic strobe effects like described above & would cost 4 faders. :( For the show on sunday I used an additional LightCo 12/24 for Strobe controlling...but i fear, that is no permanent solution. :-( Quote So, if you don't start drinking...I'm gonna leave!!!
Haytech Posted November 9, 2007 Report Posted November 9, 2007 Hi I am back for good :-)so my soulution for your problem is patch strobes on preset faders i.e. strobe1 dim/rate 44/46 strobe2 dim45/46 now you can adjust speed with one fader 46 program 44 and 45 on different submaster. you can reach your effect. Quote Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
Morn Posted November 12, 2007 Author Report Posted November 12, 2007 Morn said: BTW: Assigning the strobes on the faders isn't an option, because I have to control 84 PAR-Cans, 4 8Lights and 2 Theater Spots with them and there is no single fader left anymore. sad.gif Hi Haytech...thank you for your suggestion, but that is the state very similar of what I had before I extended the lighting system two weeks ago. Actually I have to control 60 cans (30 channels) for disco & 24 cans (12 channels), two theatre spots (1 channel), four 2KW 8-lights (4 channels) and an 2KW PAR 64 Floor-ACL Bar (1 channel) for stage lighting. For my two disco strobes I need four extra channels ( or a minimum of 3 channels if I patch strobe brightness of both on one channel). Recently I bought another flash tube for a 3rd 2,5KW USDMX Strobe I found in the cellar, which is designated for live band action (for example beneath the drum riser)... At the moment I have 2 oder 3 methods of resolution in my mind, but all of them massively reduce flexibility of the lighting system, especially of the stage lighting system... Quote So, if you don't start drinking...I'm gonna leave!!!
