johannes Posted October 30, 2007 Report Posted October 30, 2007 Hi, We have two Chillis 24x10 at our theatre for five years. I have often used the feature Dimmer Law to use a channel as switch (eg. to use conventional fluorescence lights or motors). It is only now (after changing my hardpatch) that I discover that Channel 7 and 8 dont switch even when told to. (they just keep acting like the dimmer-Law was set to normal). Seems to be a software problem, since both my dimmers do this and only on channels 7 & 8. Has anybody the same problem? Do you know how to fix it (apart from repatching everything away from Ch7&8) Thanks for any suggestions Johannes Quote
KWR88 Posted October 31, 2007 Report Posted October 31, 2007 Please can you give me the dimmers software versions. This can be found when you power the dimmer on is will say Chilli 24 VerX.X As far as I know we have never had any reported problems with the dimmer laws on these dimmers and testing the ones that I have here shows no obvious problems with the law settings. Please e-mail me on krogers@zero88.com as this will be quicker to reply to you. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
