Run A Chase From Submasters
dogcop
Hi there
I have a sunstrip active- basically 10 halogen blinder effect in one.
I have created a chase whereby 1st 2 lights come on, then off and 3rd and 4th come on etc etc - and this chase runs ad infinitum.
When i run it from the memory stack it works every time.
I have transferred it to the submasters and tried both with and without time.
However every time I run the chase from a sub the 1st 2 lights come on and thats it - no chase
I go back to memory stack again and all works fine
Any ideas ????
Andy
Hi Andy
Do you have a speed set on the chase? or are you manually overriding it using the speed pot?
Do you have a show file you could email me, with the problem submaster? pkirkup@zero88.com
Also, what software version are you running - this could help us find out if this is an old bug which may have been fixed in a later version.
Thanks
Peter Kirkup
Hi Peter
I have now mangaged to solve the problem :unsure:
Normally when I run subs, i just press the button underneath the fader hence the no chase!!!
Push up the fader and voila - mucho embarresssment
note to self - try the leedin obvious first !!!!
thanks for your time tho'
Andy
