Jason DAvies Posted September 8, 2007 Report Share Posted September 8, 2007 Hi Have 2 betapack 3 units. 1 working fine, the other seems to be a little confused as it thinks channel1 is channel2 & channel2 is channel1. Although the default settings are being used. All the other channels working fine. Have reset dimmer pack back to default settings several times via the Hidden Options. any suggestions gladly received regards Jason Quote Link to comment Share on other sites More sharing options...
KWR88 Posted September 14, 2007 Report Share Posted September 14, 2007 I think that I have already spoken to you about this then. My best guess is that an output connection has been swapped. Possibly from the triac to the actual socket/terminal block. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
