Greetings to all,
I was wondering if it would be possible to hook up an external SMPTE time code generator directly to the Fat Frog, using the TC to trigger cues? I know the Frog Box operates on this principle, but was wondering about using an "off the shelf" TC generator?
Thanks for your time--John
John Adamson
Hi John
The Fat Frog itself does not support SMPTE timecode. There is an optional upgrade card available which adds SMPTE, MIDI & ChilliNet capabilities to the Frog range but this must be fitted to a Leap Frog or above - the Fat Frog does not support it. If you have a Leap/Bull/Mambo Frog, or a Frog Box, then any SMPTE source should work fine - just remember to set the Frame Rate in Super User.
I hope this helps
Peter Kirkup
Follow up question...
Peter,
I have another question about SMPTE TC and the Fat Frog. You had stated that the board does not support this protocol, yet when I scroll through the Playback options, SMPTE time code is clearly displayed as an option in the Trigger field. Can you please clarify this further? Thanks,
John Adamson
John Adamson
This is due to the fact that quite a lot of people use the Fat Frog as a programming tool for the Frog Box - they can set up their cue stack using SMPTE timecode references, then load it into a Frog Box to playback to timecode.
Hope this clears things up.
Peter Kirkup
