Smpte Time Code
JAdamson
Greetings to all,
I was wondering if it would be possible to hook up an external SMPTE time code generator directly to the Fat Frog, using the TC to trigger cues? I know the Frog Box operates on this principle, but was wondering about using an "off the shelf" TC generator?
Thanks for your time--John
John Adamson
Hi John
The Fat Frog itself does not support SMPTE timecode. There is an optional upgrade card available which adds SMPTE, MIDI & ChilliNet capabilities to the Frog range but this must be fitted to a Leap Frog or above - the Fat Frog does not support it. If you have a Leap/Bull/Mambo Frog, or a Frog Box, then any SMPTE source should work fine - just remember to set the Frame Rate in Super User.
I hope this helps
Follow up question...
Peter,
I have another question about SMPTE TC and the Fat Frog. You had stated that the board does not support this protocol, yet when I scroll through the Playback options, SMPTE time code is clearly displayed as an option in the Trigger field. Can you please clarify this further? Thanks,
John Adamson
John Adamson
