jlipari Posted July 30, 2007 Report Posted July 30, 2007 I have a suggestion for a software update... I am not sure if this is possible for you to do because channels 25-48 are submasters while in run mode. I was wondering if there was an easy way to access those channels. I would prefer to have them on there own bank of faders... rather than having to swap using the flash button on preset A bank. Is there any way of doing this currently, will there be in the future? i hope you understood Quote
Paul Posted July 30, 2007 Report Posted July 30, 2007 If you're not using the submasters, you can just program each of them with a single channel, so that you have access to 25-48 in Run Mode without needing to page the top bank. If you are using the submasters, then there aren't any faders available for 25-48. You could though connect another desk to the DMX-IN, and this would be mixed HTP to give you control of the other channels. Quote
jlipari Posted July 30, 2007 Author Report Posted July 30, 2007 thankyou paul... and thanks for your quick response. thats a great idea... Quote
