Can you untag an entire fixture?
for example if i wanted to program a par chase without having any movers programed in, so that when you re-play the chase the movers wont move into the position they were in when the par chase was programed.
sorry for the ramble i hope you can understand it!
Once you're in Partial mode, Press and hold the fixture button for a couple of seconds (until the yellow LED goes solid) to untag the whole fixture. You can do mulitple fixtures by pressing and holding the first and last, in much the same way as multi selection.
Peter Kirkup
