Jester Operating Software version 2.1 has been released, and is available for download from the Zero 88 support website. CLICK HERE.
This contains the following changes from version 2.0:
  • [JES-531] - RUN MODE - Pressing Go mid-fade no longer snaps to the end of the current crossfade before starting the new crossfade - it now fades from the current memory stack outputs.
    [JES-532] - PRESET MODE - If Preset A faders are used for live Auxiliary control, they need to be moved back to their previous positions before they regain control of the Presets. The LED in the Preset flash button will flash to indicate that the corresponding fader needs to be moved before control is regained.
    [JES-545] - RUN MODE - After adjusting a single Submaster Chase or Memory Stack Chase using Shift and the Speed Control, on releasing Shift, other chases no longer snap to the new speed.
Instructions for performing the update are also available from the link above.
This topic is now closed to further replies.
