orlando Posted July 6, 2007 Report Posted July 6, 2007 Hi, I know that you can program a chaser on any memory of the fatfrog-desk and then copy it to a submaster. It would be comfortable - at least for me - to program a chaser directly to a submaster or at least copy it fully to a submaster - not only as a referrer to a memory. Bye, Orlando Quote
Kirkup_xp Posted July 8, 2007 Report Posted July 8, 2007 Hi Orlando The feature you suggest has been asked for a few times, however in order to implement this would require a fairly major rewrite of the submaster data structure internally, not something likely to happen at this stage in the Frog software. However, the new Leap Frog 48 and Leap Frog 96 give you this ability straight out of the box. Note that we have changed the chase recording method, inline with the Jester, so you now must attempt to overwrite step 2 over step 1 and then choose "turn into chase". I hope this helps Peter Quote Peter Kirkup
