We have a a fat frog and chilliPro that control the lighting rig. I want to run a beta pack onstage. I want to run the beta pack though the fixtures, I tried writing software with frog editor but only use dimmer once, What can i do? to create the right software?
Hi
You can only have one HTP dimmer channel in any fixture. You can however have multiple Colour, Beamshape or Position parameters. So, you could set your fixture up like this:
Dimmer: DMX 1 (Brightness)
Dimmr2: DMX 2 (Beamshape)
Dimmr3: DMX 3 (Beamshape)
Dimmr4: DMX 4 (Beamshape)
Dimmr5: DMX 5 (Beamshape)
Dimmr6: DMX 6 (Beamshape)
The problem you will have using this fixture is that Dimmers 2 to 6 will follow the LTP Fade Time and the Beamshape action (Fade/Snap). These parameters will also be treated LTP so raising a submaster with them programmed at 0 will force the dimmers to 0.
A better way to do this (assuming you're not using the fixtures for moving heads, etc), is to patch a single "Dimmer" to each of the first 6 fixtures. There are profiles in the fixture library already for <Conventional> Dimmer. Patch these to fixtures 1 to 6 and these will work as expected. Bear in mind that if you press HOME these channels will snap to full.
Hope this helps.
Peter
