I have a small problem with frog2 and motu ultralite. Frog doesn't detect the timecode I'm sending with my ultralite smpte generator. Framerates are same in both machines. Ultralite does detect the timecode if I send it from output to input. My software version in frog is 4. Thanks for help.
Have you performed the two firmware updates in the Desk Information screen in Setup? Hold down SHIFT+CLEAR in this screen to run an update - if the update is required, the version number will appear in RED text.
Peter Kirkup
