How do I Disable Solo on some Channels ?
Situation: Bull Frog, Version 10.?
Front Pars on Generics, 1 to 12,
Backlight on 13 to 24
Effects (Blinder ACL`s) on 25 to 30.
When using the Solo Flash Button
I would not like to get any Generic Channel on 1 to 12 getting off.
(if they are on via Channel or Submaster)
Is this possible with Version 10.x
best regards, pollywog
Hi Pollywog
Your best bet would be to record a submaster with the solo data (blinders @ full) and the stage data (front pars) on it, then solo the submaster.... this would prevent the channels from dipping. Alternatively just use "Flash" mode :)
:cry: :cry: :cry:
Have you ever done programming a light show ?
I think you do not get the situation.
Situation:
4 Front Colors: Blue, Red, Yellow, White
6 Break effects: 2 Blinder, 4 ACL Sets
Your Succes:
Page 1
Sub 1: Front Blue Blinder 1
Sub 2: Front Blue Blinder 1
Sub 3: Front Blue ACL 1
Sub 6: Front Blue ACL 6
Sub 7: Front Red Blinder 1
Sub 24_ Front NC ACL 6
How should this work if I would like to use combinations of Front Colours ???
Don`t tell me to go one at page 2 ... with all the possible combinations :(
am I the only one who needs to disable some generics somewhere in the Setup to avoid them getting of when using the Solo functions :?:
If I use the flash mode how are the backlights going off when using the effects ?
