Frog Genius Posted May 18, 2007 Report Posted May 18, 2007 Eh, so ive gone to a fresh memory, held in the MEM TYPE button and then i have pushed up the faders i want and then pressed program, then it came up with the next step (2) and i pushed up some other faders BUT: 1) It doesnt seem to show the steps on the cue stack (Playback) ie 27 27.1 27.2 2)I cant see the "Shots" attribute like it says in the manual 3)if i hit finish, then start the chase (Pressing GO from the que before) it does nothing Help? Also how do i make a chase go automatically? as in i hit go and then it automatically plays through steps 20 20.1 What am i doing wrong? KNine? Anyone? Quote
Frog Genius Posted May 20, 2007 Author Report Posted May 20, 2007 Above post edited to include more information. Quote
Kirkup_xp Posted May 21, 2007 Report Posted May 21, 2007 Insert memories (27.1) and chase steps (27, Step 1) are different. Insert memories are used for putting a cue between 27 and 28 that will respond to a trigger (normally the GO button). Chases are a series of Step memories run in sequence. In version 10.8 software, the chase steps won't run unless the Playback X (or Submaster fader) are above 0. Quote Peter Kirkup
