I have a little problem with the Active + enter combination. For example if i push up the first five udfs about 50% and press active + enter they go to full in the program window. I have intensity recorded to the faders. If i press active + the button below the fader it work's fine and goes only to 50%.
The other problem is that always I press active + enter every fixture that has been actived before comes to program window with intensity 0 and tagged even if their faders are in 0. The first problem occurs also in phantom frog but the other doesn't. 8O
  • 2 weeks later...
Hahaa I finally got it. I have to press clear once after the active + enter and tag the attribute. After that I have the dimmers in the program window how they should be. I still think that is a little bug or feature. :evil:
