Deathride Posted February 12, 2007 Report Share Posted February 12, 2007 hi i have tried this however the imove lantan does not respond ... all it does is goto prism and scroll the colours and gobos Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted February 12, 2007 Report Share Posted February 12, 2007 Does the lantern respond if you address it to DMX1 and use the channel faders to control the attributes? Quote Peter Kirkup Link to comment Share on other sites More sharing options...
Deathride Posted February 13, 2007 Author Report Share Posted February 13, 2007 I will double check this but i do not believe so .... i have to use a 5 to 3 adaptor pin 2 is hot .... cheers for your help btw Quote Link to comment Share on other sites More sharing options...
Deathride Posted February 14, 2007 Author Report Share Posted February 14, 2007 Just checked and found out it was the cable converting 5-3 pins i have now sorted the issue out and the fixture works a treat thank you Quote Link to comment Share on other sites More sharing options...
