ET Posted January 10, 2007 Report Posted January 10, 2007 Hello I`ve got a problem with my Fixtures Programm. If I push the Home Button all DMX Settings go to 255. ET :x Quote
K-Nine Posted January 10, 2007 Report Posted January 10, 2007 Which fixture type are you using ? Is it one from the Fixture Library or one you have created yourself with the fixture editor ? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
ET Posted January 10, 2007 Author Report Posted January 10, 2007 I`m create with the fixture editor myself. It´s an showtec Explorer 250 wash. Quote
K-Nine Posted January 11, 2007 Report Posted January 11, 2007 It sounds like the default values of all your parameters have been set to 255. Normally this is NOT the case. Brightness/Intensity is usually set to 255 (full). Most colour and beamshape parameters normally have a default value of zero which equates to white, no gobo, no prism, shutter open etc. Please check the manual for the fixture, as occasionally parameters like shutters have a non-zero value that equates to open. Pan and tilt parameters are normally set to 50% (ie 128 for 8 bit parameters or 32767 for 16 bit parameters). If you could send us the DMX channel assignment data from the user manual or a link to the user manual then we can check the default values and add the fixture to our library. Hope that helps. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Kirkup_xp Posted January 11, 2007 Report Posted January 11, 2007 Attached is a fixture profile for the Explorer 250 Wash created from the user manual. Try this and let me know if there are any problems with it. Peter Quote Peter Kirkup
ET Posted January 11, 2007 Author Report Posted January 11, 2007 Thank you for Help, The Fixture Parameters was wrong. It`s OK. The Fixture from Kirkup_xp is OK. Thank you very much for the fast Help Quote
