Sign in to follow this
Bret
Fat Frog
If I save multi-functional fixtures with the lamps in a submaster, the settings for the fixtures are not saved, although all settings ( here in the full mode & I’m using version 9.0 ) are exactly as in the handbook...
For any assistance or tips I'd be greatful - got a show soon
Thank you
There's a couple of things you need to check:
Super User -> Desk Setup -> Desk Defaults -> Submaster -> Sub Data
(make sure this is 'Gen&Fix')
Also make sure that the LTP Trigger Level on each submaster is set to something sensible like 5%. If you've set this to 0% or 100%, then the LTP parameters (Colour, Beamshape, Position) might not be triggered when you raise the submaster fader.
