ryandell Posted December 5, 2006 Report Posted December 5, 2006 hi, I am programming on a pc and would like to know what the keyboard shortcuts are for the fat frog. thanks ryan Quote
Kirkup_xp Posted December 5, 2006 Report Posted December 5, 2006 Unfortunately there arent many actual keyboard shortcuts for the Phantom Frog application. The F1 to F4 keys replicate those on the desk, and the keyboard itself works when naming etc. + and - are replicated by the vertical arrow keys, whilst < and > are replicated by the horizontal keys. Contrl+F1 thru F6 replicate the external triggers on the 8 pin DIN. Finally, with Scroll Lock disabled, the ENTER button acts as a GO button. HTH Quote Peter Kirkup
ryandell Posted December 6, 2006 Author Report Posted December 6, 2006 Hi, OK, that makes controlling the board a bit easier, thanks ryan Quote
billy J Harrison Posted June 13, 2008 Report Posted June 13, 2008 If you plug in the keyboard to the back of the desk BEFORE plugging the desk into the mains then you can, press F2 and then press the memories button to name a memory press F2 and then press a submaster button to name a submaster Press F2 and then hold down an attribute (colour, beamshape etc) to name a pallet press F1 and then press memories, submaster, output or an attribute to lock the monitor to that screen. when on the memories, type a memory number and then press enter twice to go to that memory One thing i do is program the memories to the channels of dimming eg. memory 1 is channel 1 at full memory 2 is channel 2 at full etc. and then you can just type in the number of the channel you want to focus and press enter twice. I save that on a seperate floppy so i can have it anytime Quote
