pyro Posted November 24, 2006 Report Posted November 24, 2006 Does anybody have a fixture file for a showtec explorer 250 pro spot? The fixture library only has the 575 spot. thanks Quote
Kirkup_xp Posted November 24, 2006 Report Posted November 24, 2006 If you can provide the DMX information for the fixture, I can create a profile for you - at present, I can't find the information. Quote Peter Kirkup
pyro Posted November 24, 2006 Author Report Posted November 24, 2006 Thanks, playing with the fixture editor could you check this please? <attached> thankyou Jon link for the manual http://webdisk.planet.nl/highl007/publiek/...oadType=activex Quote
Kirkup_xp Posted November 27, 2006 Report Posted November 27, 2006 The fixture file you created had a default value of 0 on the Shutter channel, which means that when you homed the fixture the dimmer would be closed. I have edited the fixture file to include a little more information (RGB details for colours, Macros, etc) and have altered the names of the parameters to match our standard naming. The modified file is attached. Peter Quote Peter Kirkup
