At the moment you can only set the fade time using the pot on the front panel. To simply increase the maximum fade time on the pot would offer lower resolution, so it's not an ideal solution. It has been suggested (HERE) to allow numeric entry of fade times, so you could set both longer and more accurate fade times. This has been logged as a suggestion for a future software update:
JES-515 - Numeric entry of fade times.
