Posted (edited)
You can program a memory as a sequence (which is I think what you want).
In program mode, press and hold the Memory Type button until the LED changes to Sequence. Setup a stage picture, press Program. Press Add Step, program the next stage picture, press Program. Continue like this for all steps in your sequence. If necessary you can insert steps between already programmed steps using Add Step.
The manual is available on this website if this explanation is too terse (same for MkI and MkII Alcoras):
http://zero88.com/support/index.php?/Knowledgebase/List/Index/50/downloads
See page 24
You can copy and paste individual steps (but not a whole sequence). See page 28.
The direction of the chase is set when the chase is run. See page 33.
Good luck.
Edit: Update manual location.
Edited by kgallen
