elli Posted September 14, 2006 Report Posted September 14, 2006 if i have my show programmed and i edit a fixture ie mac500 is there an easy way to change this in the q before, eg cue 10 mac @255-255 pan and tilt lamp on edited cue 10 so mac @150-150 pandt with lamp on is there an easy way to put this into cue 9 as a move to position with lamp off without going into edit and slightly adjusting all parameters as i do at the mo, it takes forevvvvvvveeeerrr!!! Quote
Kirkup_xp Posted September 14, 2006 Report Posted September 14, 2006 Unfortunately the Frog range do not have a move on dark feature at present, which is what you are asking for. This is something we're looking at doing in the future, so keep checking back. For now, you'll have to continue manually programming the move on darks. Peter Quote Peter Kirkup
