amillar Posted July 24, 2006 Report Posted July 24, 2006 Is the Jester Power supply compatible with the FatFrog - ie having a Jester as a backup desk doubles as a spare power supply. Thanks Andrew. Quote
Kirkup_xp Posted July 24, 2006 Report Posted July 24, 2006 The power supply supplied with the Jester and Frogs is the same unit. Older Frogs were supplied with a different power supply, however both are compatible throughout the range. The same power supply is also supplied with the Juggler. The Frog 2 power supply is also compatible with the all the other desks, although you must use a Frog 2 Power Supply for a Frog 2 due to the high power requirements of that desk. Hope this helps. Quote Peter Kirkup
amillar Posted July 24, 2006 Author Report Posted July 24, 2006 Thanks for the quick reply. Andrew. Quote
