lieven Posted July 20, 2006 Report Posted July 20, 2006 Hi, is it possible to copy a chase (with all the steps in one time) to a new submaster? in that case it would be possible to program al your chases in advance and decide on each show wich chases you want on a the different submasters ? or wil this be possible with an update ? now the copy function allows only to copy a chase step to a submaster Quote
Paul Posted July 20, 2006 Report Posted July 20, 2006 The copy function (either in Program Mode or Run Mode) simply takes a snapshot of the current outputs into an internal buffer. It wouldn't be possible to copy an entire chase, since a chase could potentially have anything up to 999 steps, and there's not enough memory in the desk to do it. Quote
bjkered Posted February 17, 2010 Report Posted February 17, 2010 I was just wondering if this is still the case after all the software updates. I was programmimg a small show and had set up a couple of moving heads on a chase in Mem. I was looking to repeat the mem chase at a few different points during the show, with out having to reprogramme ever time ( which is what i ended up doing Thanks Derek Quote
Paul Posted February 18, 2010 Report Posted February 18, 2010 If you're using moving heads, a JesterML or JesterTL desk would be better. These desks allow you to copy entire chases. The basic Jester doesn't. Quote
jw-lighting Posted June 2, 2010 Report Posted June 2, 2010 It would be very nice, if you can copy a whole chase in future software versions. Maybe you can just store the hardware memory-address of the chase to copy in the hardware memory instead of the whole chase and copy directly into the submaster/memories when the chase is pasted. just an idea. regards, jw-lighting Quote
