Hi all.
Like the description says, im looking to somehow use non-dims on a fat frog.
Is there a way to set a channel's dim curve to non dim, or is there a profile for one?
Must be a way surely! Every other desk i know can do it lol.
BTW, the racks im using are betapack ones, so can't set a channel to non dim on the rack end.. unless theres a magic function ive not discovered on my beta's!
Thanks for any help.
There's a couple of topics HERE and HERE which should answer your question.
Basically you can't set a HTP (brightness) channel to non-dim, but there is a trick you can do by controlling the channel as an LTP channel (assigned as a fixture) and then using 2 submasters (one to turn it on and one to turn it off) with the relevant LTP attribute set to snap.
