samcoombes Posted July 10, 2006 Report Posted July 10, 2006 to make scrollers change nice and quietly, i need them to do this over 6 seconds or so. however, i also need another cue to happen whislt the scrollers are changing. can I overlap 2 cues? Quote
Kirkup_xp Posted July 10, 2006 Report Posted July 10, 2006 Absolutely. Set a fade time of 6 seconds in the first cue. Trigger that cue, then trigger the next cue and both fades will be happening simultaneously. You may have problems if you want the second cue to be automatic, however, as the wait time applies once the cue has completed. Hope this helps Quote Peter Kirkup
samcoombes Posted July 10, 2006 Author Report Posted July 10, 2006 thanks - so is it not possible to trigger the next cue automatically when the scrollers are say, half way through chaging? Quote
Kirkup_xp Posted July 10, 2006 Report Posted July 10, 2006 You could always program the intermittant scroller state into the first cue (say, at frame 3 if they were going between frame 1 and frame 5) over 3 seconds, then program fram 5 in the second cue. That would do what you want Quote Peter Kirkup
