vfc2791 Posted June 23, 2006 Report Posted June 23, 2006 I am interested in buying a FATFROG. Can I "grab" a moving fixture and control it manually to follow a subject? Thanks, Vic Quote
K-Nine Posted June 23, 2006 Report Posted June 23, 2006 Yes, you can select a fixture and control it's pan and tilt movement live using the control wheels, but I don't know how easy or accurate that would be :? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
ice Posted June 23, 2006 Report Posted June 23, 2006 In order to use yokes as follow spots you require very good coordination on the wheels. I don't think your going to manage unless it only requires a bit of left-right panning. But if you need real follow spot operating, you shoud use a follow spot and not a yoke Quote > 500 posts, time for a new T-shirt?
