Christopher Snape Posted June 20, 2006 Report Share Posted June 20, 2006 When I have a cue playing and I have an zoom effect (for example) running in a fixture in that cue (nothing in the programmer), when I go to add a colour effect (or any other effect) into that same fixture, as I select the fixture it automaticly loads in the previously recorded effect parameters which means that I cannot alter the new effect without changing the already recorded one? Is there a way that I can layer effects into the same type of fixture? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted June 21, 2006 Report Share Posted June 21, 2006 If you select the fixtures and use the Effect Window to build your new effect, you will find that you can individually modify each parameter. At present the Effects wheelgroup controls all outputting effects. HTH Quote Peter Kirkup Link to comment Share on other sites More sharing options...
