Just been trying to patch sequential dimmer numbers onto the same channel number - no go! If the dimmer numbers are at least five numbers apart, then 80@70 followed by 80@75 will patch dimmers 70 & 75 to channel 80. 80@70 followed by 80@71 results in only 70 being patched. Am I missing something? Software is version 3.0.8.
Any chance we could have a patching syntax that includes '+' and 'thru'?
Thanks,
Hutch
Confusion can sometimes arise due to the terminology used especially when it comes to channels, fixtures, dimmers, dimmer numbers, DMX addresses etc
Am I correct in assuming that you are trying to patch a single channel fixture to several consecutive DMX addresses ?
I have just tried it here and it seems to patch the dimmers OK and output the data on the correct DMX output channels.
Frog 2 Reference # 7219 - There appears to be a bug in the display of the patch data in the Outputs View of the Patch.
Please can you check what you see in the other views of the Patch screen - Fixtures View and Channels View.
Bran Media | Myspace
Hadn't thought to look at alternate windows, but have now looked at the other windows and the patching is correct. So it is just the output display. Thanks...
I keep on having the same prob.....patching 2 dmx channels to one fixture channel. results in random results......
Are you saying it is not actually patching the fixtures correctly ?
When I tried this the other day the fixture was patched correctly and output the data on the correct DMX output channels; it was simply the case that one of the patch views only displayed the first instance that the fixture was patched to.
