Ianto Posted June 5, 2006 Report Share Posted June 5, 2006 I've got a Sirius 250 whose number 12 submaster has stopped working properly. It won't respond to its fader, but it will respond to the bump button. It does however come on when the fader for the number 11 submaster is pushed up :? Any idea what might be causing this and how I can go about getting it sorted out? Regards Ianto Quote Link to comment Share on other sites More sharing options...
KWR88 Posted June 6, 2006 Report Share Posted June 6, 2006 This is due to a damaged fader 12 not being picked up by the fader decoding circuit. Fader requires replacing, these are still available - the part no is 4417000 (Alpha 10K Fader Lin 60mm : RA6044-201-15D1-B14-01G). Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Andrew Posted March 17, 2008 Report Share Posted March 17, 2008 Hi, We have a Sirius 500 that is now retired from regular use. However, we have kept it around to use as a backup desk. Recently, we discovered that at some point in the past, during handling, the desk's Grand Master slider was damaged and no longer works. Given that this is a somewhat important component, the desk is effectively useless without it. Is it possible to obtain a replacement slider? Similarly, is the PCB configured to allow the slider to be replaced and soldered without risking damage to other components on the board? Thanks! Andrew Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted March 24, 2008 Report Share Posted March 24, 2008 Hi Andrew As above, the part is still available. Probably best to phone the office and speak to Keith - 01633 838088 - he'll be able to talk you through the process and if necessary arrange return for repair. Hope this helps, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
