K-Nine Posted May 24, 2006 Report Posted May 24, 2006 Frog 2 Operating Software - Version 3.0.8 Version 3.0.8 of the Frog 2 Operating Software is now available from the Zero 88 Support Centre. CLICK HERE. This version contains optimisations in the on-board LCD Touchscreen firmware to make it faster and more robust. Upgrade the desk software as normal and then carry out the following to install the new LCD Touchscreen firmware on the desk: * Ensure you have an external monitor connected to Monitor 1. * Select SETUP [Clear Options] [software Versions] to display the Versions screen on the LCD Touchscreen. * Hold down the SHIFT key and then press CLEAR. The Update Firmware window is displayed on the LCD Touchscreen. * Select [LCD] and then confirm the update. The LCD Touchscreen will go blank during the update. DO NOT SWITCH OFF THE POWER WHILE THE UPDATE IS IN PROGRESS. * Monitor 1 shows the progress of the firmware update. When the update is complete switch the desk off and back on. K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
