Is there a way I can copy multiple cues across at the same time instead of copying individual cues only?
Eg:
I want to copy cues 4 thru 5 from Stack 9, to cue 1 thru 2 in stack 1.
Then
I want to copy cues 8 thru 11 from Stack 9, to cues 3 thru 6 in stack 1.
Thanks
At the moment I believe it is only possible to move, copy or delete a single cue at a time.
We are planning on improving the command syntax in a later version of software to allow you to move, copy or delete several cues (or other items) in a single command.
Bran Media | Myspace
